Ir para o conteúdo principal
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Perguntas Visualizar todos
iPad 2 Logic board replacement
If I an activation locked ipad 2 and I cannot get in contact with the previous owner, will replacing the logic board bypass this so that the iPad isn't connected to the previous owner anymore? I have a broken/unusable iPad 2 for parts and I could try to swap the logic board if you guys thinks this will work.
I think the IMEI number is connected to the previous owner. When you connect your iPad 2 to iTunes, iTunes will send the IMEI to Apple server to check if it's connected to an account. IMEI is usually buried in the logic board. So, I think, if you change the logic board then you will get new IMEI number. Please correct me if i am wrong.
Esta pergunta é pertinente?
Pontuação -1
Adicionar um comentário
1 Resposta
Changing the logic board will solve your problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 253
