iMac keyboard not working
my iMac keyboard is not paring with my iMac can't login
Esta é uma boa pergunta?
Well let's start with the basics:
1) Is the keyboard powered on?
You can hold the power button on the side of the keyboard and you should see a green LED appear in the top right corner.
2) Does your bluetooth mouse still work?
This can be important in knowing if the iMac's bluetooth card is working properly.
Hope this helps!
Esta resposta foi útil?
I am having a similar issue. I changed the batteries and now the keyboard won't pair. I can't use the keyboard to log in and fix the issue of pairing - vicious cycle here. If the keyboard worked and I could log in, then I could fix the pairing issue. Haha. HELP!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,340
1 comentário
First put in new batteries.
por mayer
