Can I just replace the attached thermal sensor?
Apple MacBook Pro "Core 2 Duo" 2.6 17"
Is it possible to replace the thermal sensor that's attached to the heat sink? Or do I have to replace the entire heat sink?
Esta é uma boa pergunta?
Lets try this first. If you have your system put back together can you download this fan & sensor monitoring app: Temperature Gauge Pro. There are others I just like this one. The free trial version should be enough for now. Post a screenshot of what it shows for us to see.
Your problem maybe something else (unless your sure you killed the sensor). In any case this will tell you if you did.
If you did kill the sensor you'll really need to replace the heat sink as it's mounted quite well (epoxied). You will also need to clean off the old thermal paste and refresh the thermal paste with a goo brand.
Esta resposta foi útil?
Because this particular MBP has had massive NVIDIA and overheating issues, replacing the heat sink is probably the best way to go. At this point, what harm can a new heat sink do? Kill it? Again? Ha! That's so not funny. I have everything stripped down again. No way am I putting that monster back together to check the temp gauge. I actually have the free trial version of TGP. Thanks for kickin it to me elementary style. Because most people just go all in, assuming that I have a clue about any of this. I've never taken a toaster apart, much less my freaking MBP. I've broken this thing down and reassembled it at least six times already. Crazy.
Hello!
I have a similar problem ? When I pulled the cable of the thermal sensor connector of my heat sink the plastic connection broke and now I have only two wires coming out of my heat sink. I can't plug it back on the logic board. Is there a solution for this or do I need to by a heat sink and a logic board?
Please Help! Thanks!
Sadly, you'll need a new heatsink.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 438
5 comentários
Why do you think you need to replace the sensor alone?
por Dan
There are three sensors. The one in the middle happens to be attached to the heat sink. Forgive my lack of computer genius. I've managed to repair the logic board, resurrecting my dead MBP. But now the fans run full speed. I know I damaged the middle sensor while taking it apart. So I'm thinking that's the issue. By your question, I'm assuming that I'm supposed to replace the entire heat sink???
por [deleted]
Dan-
I screwed up the thermal sensor that's attached to the heat sink. I pulled the connector when I should have lifted, so the end came off. (Yay!) When I put the two wires back in, I'm pretty sure I got it wrong. Everything is working normally with the exception of the computer's temperature. The fans automatically start blowing at 6000 RPM, which is ridiculous. I don't want them to burn the computer out. They weren't doing that before I replaced the logic board. When I slow them down, it doesn't make the temp any better or worse, just less noisy. I'm trying to understand if I have to replace the entire heat sink that has the thermal sensor attached to it with a new heat sink. Or if there's a way to remove the sensor from the heat sink and just replace the sensor without having to replace the entire heat sink. Man, I hope I've done a better job of explaining my question. (Probably not. But I tried. Hard.)
por [deleted]
Apple doesn't offer the part without the sensor so I don't see how you can replace the sensor alone. If the connector on the logic board is the issue you might be able to locate a new connector to fix the cable end. Apple p/n: Heatsink 661-5042
por Dan
Yayah! You just answered my question. All I needed to know. Didn't know Apple only offered the part with the senor. Hallelujah! Thank you! Okay, when I click accept answer, why does the website suddenly fall into error? Ugh.
por [deleted]
