Trackpad is not always responding to mechanic click.
So without any apparent reason my trackpad is not reacting to mechanic clicks anymore. Only when the button is pressed for a longer time it registers.Sometimes it registers a click even though none occured. All the other funtions of the trackpad are still working properly.
Tried so far:
PMC-reset
Cleaning the trackpad and its edges with a soft cloth from the top and from the bottom after removing the battery.
Esta é uma boa pergunta?
11 comentários
I found that the battery was swollen. I replaced the battery and it's working great!
por Tim Meyer
Hi, The other alternative is to turn on "tap to click" in the trackpad preferences which gets round the problem if all other repair attempts fail.
por Laurence Davis
Bizarrely, I have replaced it with a new trackpad and the problem persisted. I sceptically gave it a tentative whack (!as suggested!) and it has returned to normal functionality!! As I said, bizarre.
por pabz
Nice one Pabz! Just had the same issue today after not using mine for about 6 months. Followed your advice and give a couple of good hard whacks with my knuckles and it's sorted now haha
Thanks again mate!
por uv1977
Ha ha. Thanks pabz and uv1977. I was on the verge of getting a new mac it was getting so bad but a couple of whacks with my knuckles and it's suddenly working as smoothly as the day that I bought it.
por Matt Zeebee
Exibir mais 6 comentários
