Pular para o conteúdo principal
My screen is broken with just the black and not working
My cat was walk on the counter and when he lay down the phone slid off the counter and hit the floor which tile. My phone has cracks on it. The light goes off but the screen is black. What do i do please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
2 Soluções
Resposta Mais Útil
Ashley, sounds like your digitizer is cracked and the LCD broken. Replace the complete assembly, follow this guide to help you with that. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
It sounds like your LCD display was fractured. You need to replace it. I recommend buying the whole assembly as it is MUCH easier and looks much better, but it is significantly more expensive. You can just purchase the LCD by itself, but you will need advanced knowledge of electronic repair, tools, and patience. Here is a link to the part i recommend, keep in mind the parts are service provider specific. http://www.ebay.com/itm/NEW-Samsung-Gala...
Pontuação 0
Adicionar a sua resposta
Ashley será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 190
