Ir para o conteúdo principal
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Perguntas Visualizar todos
Why won't it turn on after screen replacement?
I just made a screen replacement on an RAZR and it looks like it won't turn on. I made the repair following the guide. When I plug the charger, a white led turns on. I tried to hard reset it and nothing happens. What could it be?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
I've double checked it and it's connected. When I try to reset it. The logo comes up but instead of start up it just goes black and nothing work.
por
Adicionar um comentário
1 resposta
Solução escolhida
Have you checked the connections of the three display cables?
Esta resposta foi útil?
Pontuação 2
2 comentários:
Today another RAZR came in with a similar problem and the battery flexible was ripped. So it might have something todo with it too.
por
Question: Did you check the battery? Of the RAZR from your original post?
por
Adicionar a sua resposta
Edgardo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 2,046
