Pular para o conteúdo principal
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
576 Perguntas Ver todas
Need microphone logic board connector
Okay, got another fix going on... Have an 15" Early 2011 logic board with a broken connector for the microphone. Looks like this can be removed and a new one soldered on. Can someone point me in the right direction for finding a replacement part?
Also, there are 2 pins broken over the I/O ports. Does this pose a problem? Are these standoffs, or some sort of ground to the bottom case/cover?
Thx,
Fred
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Comprar agora
iPhone X Fix Kits
Comprar agora
1 Solução
Solução escolhida
Fred Turner, that is reference designator J6780 which is a Molex 78171-0003 Headers & Wire Housings 3P WTB VERT HDR PICO EZMATE connector. Available at places [http://Headers & Wire Housings 3P WTB VERT HDR PICO EZMATE |like this] or Molex. com directly. The pin you are pointing to on the picture is SH0913 which is a EMI pogo pin and should not cause you any issues. I can not really see the second pin you are referring to. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 1
Comentários:
As usual, oldturkey, THANK YOU!! I feel bad having you coming to the rescue on every inquiry I've made... Where do I send the beer? :-P What's your source for all of this goodness?? Just curious...it may be Top Secret though...
por
No secrets, just years of ifixit hobbying and collecting almost 1 TB of service manuals:-) Once you have all your projects fixed will have that beer together:-)
por
Adicionar a sua resposta
Fred Turner será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 122
