Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Why aren't my MacBook Pro's internal speakers working?
About 3 years ago I spilled milk on my MacBook Pro. It was fine until a few weeks ago when it wouldn't turn on. Genius bar said it would take $800 to repair. Opened it up and scrubbed down all parts with rubbing alcohol and let sit out overnight. Started from logic board with tweezers and I heard the startup chime. Booted up as usual and brought me to login screen. Keyboard was not functioning in certain areas, but the MacBook was otherwise normal. I plugged in a USB keyboard and that worked fine. Sound was working and everything was normal. However, the sound stopped working yesterday. No startup chime or anything, and when I went into system information, it said that no internal speakers or Microphone were present. It does not recognize headphones either. The internals are not corroded so far as I can tell. I've taken out both speakers and rubbed the connections with isopropyl alcohol. What could be wrong with it and how do I fix it?
This is what I see when I go to system information and go to the Audio tab:
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Update:I received the keyboard and installed it. Still no sound/usb. I quit the sound driver and restarted the computer. I reset the PRAM and the SMC. I updated all software and I did a complete reinstall of the operating system, to no avail.
por
Not sure what could be causing both sound and USB problems.
por
I added an image of what happens when I go to system information and click on the audio tab. It knows that it should have internal intel speakers but it says that its value is 0, which I believe means that the Mac doesn't recognize that the speakers are connected.
por
Everything else besides sound and USB is working fine.
por
UPDATE: I just ran extended testing with Apple Hardware Test and it said "No Trouble Found". I'm not sure, but does that make it a software issue?
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
Solução escolhida
Recheck your speaker to logic board connections.
Esta resposta foi útil?
Pontuação 1
17 comentários:
I rechecked the connections, but there was no change. Could it be a partial failure of the logic board? It would seem odd for that to happen after I cleaned everything with Isopropyl alcohol and left it overnight in front of a fan. I'm not sure what steps to take from here.
por
Just cleaned the contacts with Isopropyl alcohol and no change.
por
I ordered the keyboard replacement, which should be here Friday, I am wondering if that could be causing the issues.
por
Do you see a red light in the audio port?
por
No, and I checked with a plastic pick to see if any debris had flipped the audio switch on and it was clean. I plugged in and unplugged a headphone adapter several times and it had no effect.
por
Exibir mais 12 comentários
Hi,
I had the same problem, and I resolved it today. I had checked the speaker connections but they were all in tact. I ordered a brand new logic board and put it in today. When I turned on my computer the speakers worked great.
Pontuação 1
1 comentário:
Would it be possible for a USB sound card to fix the issue?
por
Adicionar a sua resposta
Robert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 5,301
