rpm to ssd upgrade hard drive
Can i upgrade to a 120 gb ssd hard drive from a 5400 rpm hard drive?
Esta é uma boa pergunta?
Any 2,5" SATA SSD will work.
Esta resposta foi útil?
Agreed +
I use Crucial RealSSD in my iMac and a Corsair P256 in my MacBook Pro
to change the cabling from ZIF to PATA/SATA and also need a way to secure the smaller drive inside the case so it didn't rattle around and disconnect. (I suppose a dab of Silicone would work for that).
If you accept this answer please remember to mark it.
Good Luck,
N.
It'll be much easier to buy a 2.5" SSD and not get a 1.8" as the form factors and the screws are identical.
but you should use a 3Gbit/sec. interface with the drive for best results though ..
elaborate on this please.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,577
