Pular para o conteúdo principal
bracket left over from strip down
Hi
I changed the headphone jack assembly on the iphone 5, so had the phone on bits, but as I was taking it apart, I noticed a bracket was inside the frame, I thought id spot where it went on the reassembly, but I didn't! Anyone know where this part is from?
http://i871.photobucket.com/albums/ab272...
As it happens, the headphone jack doesn't work, charger and speaker does. Is there anything obvious I should look for when opening up again apart from making sure everything is seated? I did swap the resistor over to the new one, so that can be ruled out.
Many thanks
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
3 Soluções
Solução escolhida
It is the rear mic bracket.
Esta resposta foi útil?
Pontuação 2
This pic should help you
Pontuação 1
Comentários:
How did I manage to forget that part????
I've ordered one of those whiteboard magnetic mats now, I don't fancy mis-placings any more paets on future jobs!!!
por
That looks like the bracket that holds the mute switch button in place
Pontuação -1
Comentários:
Ok, I'll open it back up tonight!!
Thanks.
I could tell you everytjing about the 4/4s but ive not done enough 5 to know every partuet!
Cheers again
por
No, this should be the rear mic bracket.
por
Adicionar a sua resposta
Duane será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 149
