Why is my home button stuck?
I never had a problem with it, and today I pushed it in and now its permanently stuck in. It still works but i have to push it in REALLY hard. Its so annoying.
Esta é uma boa pergunta?
I would suggest Taking the front panel off and putting it back on with the button in the right place.
Esta resposta foi útil?
The 1st Gen Touch has just a little bit of plastic holding the touch button in place. It's possible that this plastic is displaced and the button can now recess.
You can try to pry the button back out to see if it is loose, but this may kill the limited function you have as it is.
Other than that, open it up and check it out!
I hope this helps.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,070
