Why won't my tablet screen turn on?
I charged my tablet and it powers on, but the display won't turn on. What do I do?
Esta é uma boa pergunta?
If the tablet is charged, you probably have a dead display. I would suggest replacing the display assembly. Follow the steps here Xoom Assembly Replacement
Esta resposta foi útil?
Thanks Andrew! Everyone here is so helpful and amazing.
You're welcome! Glad I could help!
MY Xoom died and I put it away for several months. Finally I contacted Motorola and they said hold down the volume buttons when you turn it on and keep them on until it finishes booting. I thought Yeah Right but I did it and it worked, still using it after a year or so since it happened. This is supposedly a cure for several things that may happen. I don't use it much and mostly just for reading books and a few games but I think it's great.
unbelievable... I thought my xoom was now totally dead after days of not powering on but appeared to charge OK and was looking on ebay for a new one. Found ifixit as a last ditch attempt to take apart and look for something loose (nothing seen). found Toms entry, pressed the vol and power buttons and it sprang into life... thanks Tom
I preformed the above and the screen with the Motorola emblem and words -starting R&D protocol support. ...
And nothing else.
Can anyone help. ..?
After an hour I came back turned it off and turned it back on it is working!
Unbelievable!
1,2,3. Done, thanks a lot friend, it works.
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 2,346
