16 Hp Kohler engine. Won't Start, no fire. Why?
Have a 16 Hp Kohler engine. Model CV16S - 43519.
Will not start. Has no fire at spark plug wire. Is full of electronics. Looking for Site or Help in how to test the Engine Rectifier, Stator, Engine Module and Digital Module.
The engine spins freely with starter, but will not start at all. Acts like it may start when you let up on the key, but doesn't start.
All these parts are expensive to replace. I'm looking for any help to be able to test and fix without replacing all the parts on the mower to get it running.
Thank you and have a wonderful day.'''
Esta é uma boa pergunta?
9 comentários
See if you can get the service manual from http://www.kohlerengines.com/manuals/lan... here. The model number you posted does not yield any return.
por oldturkey03
Thank you for the response. I'm like you, I can't find the manual for this model on that site.
Do you know if I can replace the ignitor module with a standard one, and do away with the digital module? Do you know of any way to test the digital module or if I can bypass this somehow? It seems that everywhere I look, I run into road blocks and find no information for this motor, except for the Craftsman site (which is no help).
por Jeff
hello my kohler engine start when it going on load one coil dont work.and it not bare load.i have change 3 coil but problem is same after 15 mint one coil dont work
por saba
Have had the same problem and have ordered a new coil will let you know if this solves the problem.
por Ray
Look under kholar command for parts they put our kholar pro cv16s under those
Cv16s is in with the command model's of kholar
Any part you need you'll find under kholar command that's what pops up for me it's like they don't have kholar pro cv16s replacement parts.
Leave it with me an I'll get it running in four hours or less.
por Michael Bland
Exibir mais 4 comentários
