Kenmore Refrigerator 106.8596880 cooling won't stay on?
My Kenmore refrigerator 106.8596880 stopped cooling/freezing. I I bought a new thermostat control only to discovered after I installed it, that it was not an exact parts match, it fit but the dial numbering is off. The part number was the same but I found out later that this part comes in different models based on the specific unit. Anywho, the fridge started cooling so I was fine once I determined what was high, low, off, on. After about a few days, the fridge was dead silent though it had power, as the lights worked. I tapped the temperature control housing and it came on and began to cool however, I found it randomly stops cooling and I have to give it a few sharp taps to get it to start running. The fridge has an energy saver switch that I use to alert me when the fridge is not running as it should. If the light is out, I give sharply tap til the light comes on which indicates that fridge is cooling. I need to fix this problem once and for all!
Esta é uma boa pergunta?
