Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Perguntas Visualizar todos
no sound-headphones or ipod stereo
i have already replaced the headphone jack
but still have no sound-is this a logic board?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hello!
I would first check a different speaker/headphones (had to say it just to be thorough). Then double-check the connection between the headphone jack and the logic board. If this doesn't fix the problem, try another headphone jack (the one you received may be faulty as well). If this doesn't fix the problem, it most likely is the logic board.
I hope this helps!
Esta resposta foi útil?
Pontuação 0
1 comentário:
I have Samsung headphones I tried to connect to my moto G3 but it's not working then I connected it to my Sony Xperia phone it's working great with Sony but not with Motorola Moto G3
por
Hey man, i think is the usual problem with this kind of iPods, that the sound chip is unplugging from the board, and if you press the case hard enough the sound will come again.
the only solution i know is to change the motherboard. sorry.
Pontuação 0
Adicionar a sua resposta
mctune será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,682
