Weak gps signal after back plate replacement
Hello. My iphone 5s shows in maps, a big blue cirkel, in a radius off 7.5 km. its after back plate replacement. Please help. Where is the gps antenna og wires?
Esta é uma boa pergunta?
There is a screw with metal bracket on the very top end of the logic board, that's GPS antenna connector. The antenna is the top part of the case itself.
Make sure you install these parts correctly and the case is made with proper material, the aluminium contact point is properly cut open like the original case.
Esta resposta foi útil?
where the blue ring, and pile is right? http://s103.photobucket.com/user/albaek2...
Yes. Make sure that part is installed exactly like the original.
If i hold ny finger on The left side of the lock button it's know my position and when I release my finger the circle gets big again?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 470
1 comentário
por Thomas
