Ir para o conteúdo principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Perguntas Visualizar todos
Acceleromter Replacment Issue, please help
Hi, i need to replace the accelerometer in my Lg G2. A screen repair place replaced the screen, and now all of a sudden the accelerometer doesn't appear to work. I would like to know where it is located in the phone, and maybe what replacement part i could purchase. Ie. the ribbon, or board or antenna idk..
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Lincoln, hope you are aware off that changing it is not an easy task. Replacing an IC on a logic board requires the right tools and plenty of skill. Double check all your software setting, try a hard rest and re-evaluate from there. Not any ribbons or other changeable hardware involved.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for the help! So I suppose the logic gate needs to replace
por
You lost me with that "logic gate needs to replace" what do you mean?
por
Adicionar a sua resposta
Lincoln será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 573
