Panasonic KX-TG5110 Cordless Phone will not stay charged?
Charge new battery but will not stay charged for more than an hour is that the norm. when they stayed charged the whole day phones are three years old
Esta é uma boa pergunta?
Bob, the Panasonic does suffer from poor battery performance. It is a common complaint. You said staying charged for an hour, if that means that you can use it for an hour, that is actually pretty good. Anyhow, I would replace the battery one more time to make sure that the first battery pack was not of low quality. Hope this helps, good luck.
Esta resposta foi útil?
Where do you buy the batteries if phone is 6 years old?
rayford13 what model is your phone and where are you located?
It could be a bad port that appears to be charging but does not. I have also seen devices with signal problems do this. It struggles to find the tower constantly so the battery runs down quickly.
jamee, this is a 5.8GHz cordless phone. They are usually not plagued by searching for towers etc.
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 3,192
