Power button is jammed, phone won't turn on.
Hi everyone.
I recently dropped my galaxy s4, leading to the screen cracking as well as the power button being bent. It's bent inwards, and you can't push it down anymore. Not really sure what this did, but now the phone won't turn on. It only shows the galaxy display like the phone is about to turn on when you first put in the battery. This lasts for about 2 seconds then goes away. Does anyone know what I could do for this problem?
Thanks so much, really appreciate the help. Didn't get phone insurance, so I really need it fixed.
Esta é uma boa pergunta?
4 comentários
Update-
Thanks for the suggestions everyone. Was able to disassemble the phone and remove the power button. Only took about an hour! Phone is now working again, however there is no power button so I have to use a pin/small screwdriver for power button until new button arrives in the mail. It seems the problem was indeed that the impact had bent the power button in a way that it was constantly pressing down.
por Ian Jacobson
So did you remove it completely?
por bailey
So how did u fix it bc im having the same problem
por ocampojunior95
im having the same problem im about to un screw the back and see if i can fix the power button will tell u how it goes
por taelon
