Ir para o conteúdo principal
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
468 Perguntas Visualizar todos
Adapter for MBA 13" Mid 2013 PCIe drive to SATA or USB?
Hello everyone,
I work at a computer repair shop and since the new MacBook Airs have been out for a bit, we have come across instances where we are unable to get data from a machine simply because we don't have the tool to do it.
I am looking for an adapter that will take the PCIe SSD in a Mid/Late 2013 MacBook Air (or MacBook Pro Retina Mid/Late 2013) SSD to either SATA or USB.
So far, any searches have come up empty.
Any help would be appreciated.
Esta pergunta é pertinente?
Pontuação 2
Comentários:
Would this type of drive work in a Mini PCIe slot like what many systems have for Wifi/BT card?
por
sintech has them but they are expensive
por
Adicionar um comentário
2 respostas
Solução escolhida
I've faced the same problem! Sadly, there is no options right now. There are no external drive cases for the newer PCIe drives currently.
What I do is use a second '13 Air popping the SSD into it and then putting it into Target Mode with a USB cable copy off what was needed.
Esta resposta foi útil?
Pontuação 1
Comentários:
That is what I have been doing. Maybe, just maybe, we will get something.
Thanks
por
I am looking for an adapter of my macbook pro 2013 ssd to a data 2.5 inch enclosure . Planning to use it in my 2012 macbook pro i7ghz.
Any help or suggestions is great appreciated!
por
I've found some 2013-2014 ssd to pcie adapters on ebay. Doesn't really help unless you have a mac pro to pop the ssd into or have a pcie to thunderbolt enclosure (which run about $400 ata minimum).
http://www.ebay.com/itm/2013-2014-MacBoo...
Pontuação 0
Adicionar a sua resposta
Nathan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 10,438
