Ir para o conteúdo principal
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 Perguntas Visualizar todos
Battery drops from 100% to 7%
I bought this phone from eBay. Turns out it would only turn on unless I charge it for hours! So I bought a new battery and it began charging and turning on. I disconnect it and it would be fine for like 2 or 3 minutes. Then it would all of a sudden drop from 100% to 7%. I don't think its the battery because I bought an OEM battery. But it could be defective. I'm not sure. Any help?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Does any part of the phone overheat?
por
No. Not at all. It works normal then the battery power just drops.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sounds like there may be a task left open in the background. Press and hold the back arrow to see if there are any tasks left open? If not try a soft reset first by pressing and holding the vol down+power button. You shouldn't lose any data doing this but some have reported their clock resetting.
Another thing to check. Goto settigs>Applications>photos+camera. Is Auto upload to Skydrive on or off? If it is on, your phone may have apent hours trying to upload to Skydrive if you have a slow internet connection. If connection is slow, you might want to consider turning this off.
If all else you may need to replace the battery.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jon Andrade será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 380
