Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 Perguntas Visualizar todos
I replaced the glass, but its not working...
Hi. I replaced with a new glass. I put everything on place. Also I tried second glass but its not working. I cant control it. I cant touch. Everything clean and working. But touch panel no. Need some help
Esta é uma boa pergunta?
Pontuação -1
2 comentários:
Have you verified all cables and reseated to make sure they are plugged in correctly?
por
Had the same thing, the new digitizer had a different revision number. When I found a match of the broken rev 0.0 with a displacement that also had rev 0.0 it all worked!
por
Adicionar um comentário
1 resposta
Turn off the tablet, if you can.
Hold the power button and volume down button (possibly the volume up button) down together for about 15-30 sec and see if it reboots.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ken será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 547
