iPhone 5 constantly searching after screen break.Heat from connectors.
iPhone 5 pretty bad break, constantly shows searching after powering the phone on. Had a look inside all the connectors are fine and the SIM tray looks fine too.
However I can feel heat coming from the two connectors near the battery connector as highlighted in the picture below.
Not that familiar with the board components just wondering if anyone else has had the same problem?
Best regards Thomas Lasota.
Esta é uma boa pergunta?
3 comentários
ive had a similar problem, i noticed that there is an antenna part there, have you tried applying heat incase theres a loose connection?
por Krayzee
Did you get this fixed.
Did u give it back to the customer broken?
por con
Yes, this was something that I could not repair.
por Tom
