Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 Perguntas Visualizar todos
How to fix Galaxy GT-P5113; won't turn on after water spilled on?
How can I take this apart and clean it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Steve Holland, Here is a decent teardown video. Once you have it disassembled, check for corrosion, burned or charred, as well as missing components. Clean every part with 90%+ isopropyl alcohol. do not forget all cable ends and connectors. Replace the battery then re-evaluate. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks! We'll try it in the morning and let you know how it goes.
por
Adicionar a sua resposta
Steve Holland será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,298
