Not connecting to wireless carrier
My phone is not getting any signals. I just finished changing the battery and now I'm not getting a signal. Help!
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
5 Soluções
Solução escolhida
Make sure the time and date is set correctly then give it a hard restart.
Esta resposta foi útil?
Pontuação 0
Comentários:
Are there another other connections you took out other than the screen and battery?did you pry on the logicboard side of the battery to release it?
por
I tried that. Still no luck. Any other suggestions? Thank you!
por
Sorry ment any other connections
por
I'm not sure....the battery was REALLY hard to take out so maybe I did something there? Everything else on my phone is fine. Just can't get a signal. Is the logicboard underneath the battery?
por
There Is to long black cables that run up the side of the logicboard aswel and it has 2 connections at one end and 2 at the other make sure they are connected.
If they are then try a restore for your last attempt.
Failing that you have cause damage to the logicboard
por
The logic board is what the battery and all other connections fit into did u pry on the side that the battery connects into?
Make sure this part is plugged in
Pontuação 0
Comentários:
It's plugged in :(
por
you ever find the problem? mine is doing same thing
Pontuação 0
I didn't. short answer long: I took it to an iPhone repair place and he said that I put everything back together correctly. In order for him to figure out the problem, I would've had to leave it overnight and was leaving town that night so luckily I had insurance on my phone and they just sent me a replacement phone. Have you been able to figure it out?
Pontuação 0
This is the same pry damage problem on the edge of the SIM card tray. Lots of similar posts on here lately. If you look under the black interconnect cables you will see some damaged components that need to be replaced. Not a huge problem, but you're probably best off to send this out for repair.
Pontuação 0
Adicionar a sua resposta
graceyang será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 189
