Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
484 Perguntas Visualizar todos
Why won't my washer spin or drain?
It will fill with water but won't spin or drain on its own. I can drain it if I put the hose on the ground, but not if it's in its usual spot.
Esta é uma boa pergunta?
Pontuação 32
21 comentários
washer will go into the final rinse but wont spin dry?
por
Washer will not drain
It fills & spins for a few minutes but the water is not coming out of the hoses,we took the hose off the back , the water came out of the machine
por
the same happened to me, now it will spin but it wont drain unless it on the floor
por
If my washing machine was just working and all of sudden it started spinning and shaking really hard I went to stop it fix the clothes thinking it was in balanced but now the washing machine won’t go on spin or it won’t drain but it still washes the clothes n fill up. What do that mean? And is it fixable?
por
Check to make sure stem goes in deep enough so machine knows lid is shut mine had a small piece broken off end . Just took off rubber grommet and to give xtra length and works!!!!!!!
por
Exibir mais 16 comentários
Adicionar um comentário
13 respostas
Solução escolhida
If your Kenmore 110 Series Washing Machine is not draining after a wash cycle, see the Kenmore 110 Series Washing Machine Won’t Drain problem page for possible causes and solutions.
If your Kenmore 110 Series Washing Machine refuses to spin or agitate during the wash cycle, see the Kenmore 110 Series Washing Machine Doesn’t Spin or Agitate problem page for possible causes and solutions.
Belt, Water Pump
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Esta resposta foi útil?
Pontuação 24
32 comentários:
Well for one this thing that is being called a coin trap is actually called a pin trap (I have 25 yrs of whirlpool experience including warranty work) now also if it's not draining and you put the hose down to the floor and it drains then it doesn't have a sock plugging the pump, what it more than likely is, is the thing that shifts the pump to recirculate or drain, it is actually called the wigwag assembly, it has two solenoids on each end and alls it does it wigwags back and forth until it is told to energize one of the solenoids to shift the pump into drain, how u tell which one to chk with an ohm meter is its the one that shifts the pump lever back and forth, of course this is on older machines. I've been out of the business for a little while, so anything that's been built in the last few years I can't say for sure if it's still being used, but it sounds like it is your problem with your washer, very inexpensive to fix.
por
Where is this solenoid or these solenoids located? Sounds like my problem.
por
Sounds like exactly my problem too!
por
My machine is old it fills then agitates then the next cycle does nothing no draining all you hear is the timer on the board what's the problem?
por
Jon check your lid switch
por
Exibir mais 27 comentários
Step 1: Perform a master reset
This is the first thing a person should try. Unplug the washing machine, and leave it this way for about 1 minute. Plug the machine back in, and close the machine door six times in 12 seconds to send a message to the computer to reset everything. It may not work on all washing machines, so consult the repair guide to see if it will work for this particular machine.
Step 2: Fix the lid switch
If the lid switch has become defective, it is necessary to remove it from the machine. Consult the machine's repair guide to see where it is located and how to take it out. See if the switch works when it is used to open and close the machine door. If it does not, the lid switch needs to be replaced.
Step 3: Check the water level control if the machine isn't spinning
Open the control panel, and look for the water level valve. If the plastic tube attached to it appears clogged, vinegar can clear it up. If the switch itself appears corroded, it may be necessary to replace it.
If none of these solutions work, consult the user's guide that accompanied the machine. Parts may need to replaced, or a repairman may need to be called.
Pontuação 17
5 comentários:
Amazingly this simple fix got our machine draining again. Thank you!
por
the GE website outlines this same reset technique and it solved the problem on my GE washer!
Thanks!
por
Still not working
por
THE MASTER RESET WORKED!!
Thank you!!!
por
My washer washes and gets to drain and spin but won't complete cycle
por
I fixed my washer without taking it apart! I would have had to take apart entire washer to fix clogged pump. But instead I
1) used EXTREMELY hot water and let it drain a few times, putting the hose on the ground, turn your water heater to maximum for this, you might see clumps of what is clogged coming out.
2) sucked and blew air into the hose and back out to help unclog the water pump
3) started to shake and slide the washer back and forth as it was on it's drain cycle, with the house on the ground.
4) after doing this for about an hour, THE WATER PUMP STARTED WORKING and a HUGE clump of my rugs came out of the machine.
I posted a video explaining more here: https://www.youtube.com/watch?v=hHKYhMCd... Good luck
Pontuação 5
2 comentários:
we've been doing this now 6 hours a day for 2 days our washer is clean yet still wont do anything to drain after the wash cycle..
por
Check your pump
por
My tub full of water, had NO way of draining it!! Pulled the switche, jumped the wires to bypass the switch and BAM it works!!! Thank you Karl Riker, the genius!!!!
Pontuação 5
3 comentários:
how does one jump the timer switch? on the kenmore elite
por
I pulled my wires to bypass the switch a couple months ago and worked fine but now it wont drian or spin it does agitate but wont drain or spin what can I do to fix this
por
GE washer will not spin or drain
por
I Pulled a sock from the pump from a Kenmore Washing Machine that would not drain.
Pontuação 4
2 comentários:
Had same thing with my Kenmore washer. Cleaned hoses but still had problem. Even reset washer settings because Sensors. Checked Door hing also. Decided to clean whole washer including where sensors read. Double Checked tub on correct. Washer works now. So double Check. You may come across solution.
por
My washer sounds grounded when I put on the switch I don’t know what is the problem and the water inside is stock pls help me what am I gonna do? Thank you
por
Where do I find all the parts that were named?
Pontuação 1
2 comentários:
Beko machine seems to be getting stuck on the cycles (using time save for 30 degrees should take an hr but took 2 3/4), wasn't spinning properly and once finished clothes absolutely soaking wet still. The other day engineer came and replaced worn brushes seemed ok on spin setting, on doing a 30 degree load today it's still having the same issues! Engineer will be here today by 4 but would appreciate any advice on to what someone may think is wrong before he arrives. Thanks
por
Can I download a user's manuel? Mine is lost!!
por
our kenmore 700 top loader washer seems to go through the wash cycles ok, but it does not spin enough to get all the water out of the heavy clothes. and there is some residual water in the tube, leaving the clothes sopping wet. If we put it on spin cycle again, it will then spin enough to get most of the water out and it pumps the residual water out.
what is the issue? the drain pump does work, the timer cycle does seem to actuate the proper function. ?? tom
Pontuação 1
1 comentário:
Did you fix? If so, how??
por
Washing machine not draining? If the washer won’t drain or spin, either something is stuck in the washing machine drain hose or pump, or the pump is broken. If a washer won’t drain or spin, the fix is simple if you’re even just a little bit handy with tools. We’re showing the repair on a Maytag washing machine.
Remove the front panel screws. Start by unplugging the machine and emptying the water. Bail the water out of the tub, or you can drain the tub using gravity by placing the washer drain hose on the floor near the drain or in a bucket. Clamp the hose to prevent any remaining water from running out.
Pontuação 1
1 comentário:
In the machines referenced; the sensors determine the program mode of operation. In this case the drain process is interrupted due to a shorted position sensor at the base of the drive mechanism.
por
all we had to do is tare it apart and clean the sand and build up grossness out of the motor and hose and it works done this twice on me
Pontuação 0
1 comentário:
How did you do this? Did you already know how to take apart? Was it hard?
por
The gear case may be damaged due to overloading. Sounds like it's spinning but if the tub doesn't spin; your laundry stays dripping wet.
Use the videos and step-by-step resources to familiarize yourself with the process.
Unplug the power cord and place the end under the washer lid. Close the lid.
Turn off the water. Detach hoses from the machine.
Walk the machine away from the wall about ten inches.
Tuck the drain hose under the power cord.
Use your combination Craftsman screwdriver to remove the power cord cover and the two outer screws that hold the control panel from the back.
Slide the top of the machine forward and lift gently, as it releases, push rearward until the top becomes free. Rest the open top on the machine body, use the two slots at the rear of the top. The slots fit onto the tabs that retain the rear of the control panel.
Use your Craftsman screwdriver to gently pry the bolt cover from the inside center of the wash tub. Take care, do not to nick anything. (Nicks snag fabrics during the wash cycles.)
Use a Craftsman metric socket set to remove the spindle bolt. Lift the agitator from the spindle and set it aside.
Very carefully pry the tub retainer from it's center slot. Set it aside.
Carefully examine the top of the outer tub, understand the way top is held by nubs in slots around the top of the outer tub. Use a stubby screwdriver to gently pry the plastic enough to free each nub from its slot as you pull upward. Place the top aside while noting the placement of the bleach dispenser.
Lift the tub carefully. Set it aside.
Close the top of the machine.
Find some old towels. Spread the towels over an end table, coffee table or two dining chairs placed front to front. Lean the washer forward onto the improvised towel covered work platform. Center the washer carefully and securely.
Use your Craftsman metric socket set and extension to remove the two drive cover retainer bolts. Set the cover aside.
Squeeze the connector tabs on each electrical connector. Gently shift each connector while pulling until it becomes free.
Note the location of the shift ring .
Use your Craftsman metric socket set to remove the center drive pulley nut. While rotating pulley; work the drive belt off of the pulley. Set the pulley and belt aside.
Use your Craftsman combination screwdriver to remove the two screws holding the shift actuator to the gear case body. Set the actuator aside.
Carefully lift the capacitor away from the gear case body while twisting an eighth of a counter clockwise turn. Set it aside.
Use your Craftsman metric socket set to remove the two motor retaining bolts while holding the motor. Set the motor aside.
Maintain the balance of the washer.
Use your stubby screwdriver to walk to the two wire harness retainers from the gear case body. Drape the harness out of the way.
Use your Craftsman metric socket set and an extension to remove the four gear case to tub base screws.
Pull the gear case away from the base of the washer tub while noting it's position. Compare the new and old gear cases. Check for the lower tub seal. Remove the old tub seal if necessary.
Reverse the process for re-assembly.
Do not over tighten any fastener.
Do not snug fasteners until each fastener is adequately started and each part is securely in place.
Run one normal cycle while observing the empty washer operation.
If any irregularities are noted; the washer may require a reset.
Tell each user about the cost of overloading the washer and dryer. Repeat often. Exaggerate the cost and time involved until you receive FULL reimbursement
Pontuação 0
5 comentários:
What's with all the tools being "your Craftsman ____"? Is that the company you work for or something? I don't have any Craftsman tools and didn't need any to fix my washer -- my various other brands of screwdrivers and pliers did the job well.
por
The tools were free. I used my points from buying the machine.
por
Virtually ANY other brand of tool will work , as well as being of superior quality. Craftsman Brand is now made in China from inferior and sometimes toxic, low grade materials.
Avoid Craftsman brand tools like the plague. They are useful only for holding the trash bag down in your waste can.
por
Craftsman tools have a warranty. Lifetime is the period.
por
Do i have to insured my craftsman tool after i bought to use it? Does it rebate any damages cause by my craftsman tools?
por
There are lots of reason why the washer does not drain water. If the washer machine does not drain water, the pump belt may have broken or worn out. You have to check the belt plus drain pump as well because it drains pump might be defective and replace it if it shows any wrong signs. You must identify the fault of the drain pump or drain hose before replacing. Try to remove the hoses from the pump to remove the clothing piece. Note that the water in the washing machine will come out of the holes when it is removed. There is a lid switch which could be defective because of assembling malfunction.
Test all the switches and door lock motor with the Ohm meter for continuity. This washer is implemented with a device near the water pump described a coin trap, and it could be clog so as not to drain the water. Here, washing machine maintenance tips and how to fix the leak can help to get rid of the issue.
Pontuação 0
1 comentário:
Got a front loader
por
My washing machine didn't want to start. I just took the cover off and it worked, here is a more detailed text https://www.diyany.net/laundry-machine-w...
Pontuação 0
Mine spins most of the time but when I try to wash more than half capacity load it won’t spin. If I take out all but maybe one item it will spin and drain. It’s maddening. Towels are especially problematic.
Pontuação 0
Adicionar a sua resposta
Clint será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 168
Últimos 30 dias: 822
Duração total: 981,457
