How do I remove the Logic Board from the base?
I need to replace the lower base, but can't seem to locate all the screws that attach the logic board to the base? Any ideas?
Esta é uma boa pergunta?
Make sure that all removable parts of the logic board such as RAM and the airport card are removed. Then, take out all the screws that you see on the logic board.
Esta resposta foi útil?
Hi. Thanks. There were a couple of screws I couldn't locate. There was a plastic screw which I hadn't identified and also some smaller Torx ones near the power socket. All sorted now.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 202
