one purple vertical solid line through my LCD Screen
I dont know what the problem is. Ive owned this laptop since Nov. 2008 with no issues until now. I reset my PRAM with no luck. Is my LCD screen gone bad?
Esta é uma boa pergunta?
Is the line moving or always at the same location ? Same line location when changing the display resolution ? If you don't get the line on an external monitor and the line don't change location then the LCD panel is going bad otherwise it would be a faulty (or not well seated) LVDS cable (video cable).
Esta resposta foi útil?
The line is always at the same location. how do i check the cable connection?
then in this case check the LVDS(video) and other display cables and see if it helps
If you really need a new display, fire up terminal and enter:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
This gives you the exact display specs. In this model Apple used a bewildering range of LCDs which are not interchangeble.
there are airbubbles in your lcd, it will get worse once they pop.
it happened to me. it sucks
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 50
Duração total: 6,321
4 comentários
Does this show up on an external display too?
por rab777hp
If you can take a picture of it and upload it that could prove useful.
por rab777hp
heres what it looks like
[image|46196]
por Noland
The line is always at the same location, and i dont have the right cable to hook it up to a external monitor
por Noland
