Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Repair guides for displays (or monitors) for computers or other devices with video output.
234 Perguntas Visualizar todos
External PSU and controller for TFT Acer FP558 (LCD monitor) module?
Hi. I took a TFT LCD module (and its inverter) out of a broken external PC display. I'd like to reuse this module as a display, but I'd need:
1) A controller board (is this ok?)
2) A (possibly external) power supply, which I should be able to connect to the board. Is there anything like that?
Thank you.
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Resposta
Jacopo Jannone , yes there is. I used this part for a similar project. Also check here for more. It can get a bit tricky, and I'd recommend that you try to get the datasheet for your LCD panel to get the pinout connections. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jacopo Jannone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 270
