Ir para o conteúdo principal
Generally referred to as pants. Repairs range from patching a hole to replacing a zipper.
35 Perguntas Visualizar todos
How do I sew a merino wool base layer?
I have a pair of well worn merino wool base layer bottoms that I am looking to repair. I want to know the correct way to sew this particular knit so that I can fix them without ruining the integrity of the bottoms. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I wrote a step by step instruction guide to show you how to repair a hole in your merino wool underwear. This guide assumes that you know how to thread a needle and have, at the very least, some basic sewing skills.
This repair is specifically for the crotch of a pair of Icebreaker Beast underwear. This guide should help you repair any Icebreaker, Smartwool, or ExOfficio underwear; or any other merino wool gear.
http://www.hcrbeta.com/how-to-repair-a-h...
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks Jason - SPOT ON. New LIFE to all my outdoor winter gear.
por
Jason...I need to shorten the sleeves of a SmartWool sweater. Do you know if I can do that, or should it be a professional project? Thanks,
por
Pergunta mais útil
You don't sew it, you darn it. Here's how: http://www.ehow.com/how_8790736_darn-woo...
Pontuação 3
I use wool felting to repair my wool socks and merino underwear. Works really well.
Pontuação 0
1 comentário:
How exactly do you do that? Do you just sew a patch of the felt over the area?
por
Adicionar a sua resposta
Hereks será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 24
Últimos 30 dias: 38
Duração total: 18,710
