replacing an 80gb HDD 6th Gen with larger
Hi,
sorry for asking a question that has been asked before. i have seen a few threads detailing ipod 6th gen hdd upgrades, and many thanks to all those that have answered this question before.
i currently have an ipod 6th gen 80GB.
i am hoping to upgrade it to the 160gb toshiba m6134GAL (i believe).
Simulataenously hoping to replace the battery too.
Therefore is the following list a comprehensive 'shopping list' of what I will need before i start attempting the upgrade?:
1. 160 gb 1.8" HDD
2. A set of plastic opening tools
3. a replacement rear case (If the toshiba 160gb is 5 mm, do i need to opt for the thicker case or will the 'thin' classic rear be sufficient?
4. Is there a discernible difference between the 80 gb and 160 gb battery? which would you recommend? Will choice of battery affect which rear backplate i can put on?
5. i also read that I should upgrade the headphone jack assembly if putting a larger HDD in. Is this necessary if the replacement HDD is the same thickness as the one being removed?
once again, I would like to thank you for any assistance you can provide.
Greatly appreciated
paul
Esta é uma boa pergunta?
