iMac dead after installing SSD intel 530 as second drive
Dear sirs.
I have installed a SSD Intel serie 530 as second drive.
Now the Imac is totally dead.
After disconnecting the sad from the cable it came back to live again.
any ideas?
Best regards
Bart
Esta é uma boa pergunta?
3 comentários
small update, result is the same with a different SSD.
Disconnected is starts , connected its dead.
por Bart
Can you explain how you added the SSD. Did you swap out the optical drive or did you use a second HD/SSD kit from IFIXIT or OWC to add the needed connections for the SSD.
por Dan
I have used a second HD/SSD kit.
Optical drive is still in.
por Bart
