Ir para o conteúdo principal
Informações e guias de reparo para modelos de MacBook Pro com telas de 13 polegadas.
9741 Perguntas Visualizar todos
Why my mac doesn't sense when the lid is closed?
Hi, i'm having problem with my MBP 13'' mid 2012 since i've opened it for changing RAM and clean it a little. I notice that when i closed it, the battery indicator doesn't work anymore, and when i close the lid, nothing happen, like the lid is still open. I read here on iFixit that the sensor for the closing lid is part of the battery indicator. Later in the day i'm gonna re-open it and see what happened.
What could be the problem? Is it possibile that i disconnetted it accidentally? or it's probably broken?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you snagged the ribbon cable. Check for a ripped ribbon or loose connection on the logic board.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
fvbenigni será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 173
