Ir para o conteúdo principal
Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
416 Perguntas Visualizar todos
Pergunta Encerrada
Logic Board Change to Core Duo 2
I have a Black Macbook Core Duo that I've been constantly fixing. It's last accident involved water. I cleaned the logic board up with 90% pure alcohol, left it to dry over the weekend and got it to start up and log in, only problem was that it would only do so if the battery was out and the AC charger was connected.
After a few trials it just wouldn't turn back on, no matter if the battery was out.
It's last sign of life was turning on but no chime and no screen signal... it won't turn on since then.
The battery charges if I connect the AC charger to the laptop and it goes all the way to a full charge, the light on the AC charger also turns on.
My guess is the logic board died so I looked up a used logic board for this model (its a MA701LL/A as far as I can tell, with a 4 wall thermal sensors) but not even ifixit has it on stock, all I keep on getting is 2.2GHz and up.
Would one of those 2.2GHz or 2.4GHz logic boards fit my macbook?
Thanks for your help!
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Nope - won't swap. Generally you have to stay within the same model year or holes/ports don't line up and with the extra note about the thermal sensor you have to get something that's compatible.
If you get it from some other vendor I would want a written warranty from the vendor that if the board doesn't fit you do not get charged a return or restock fee.
Esta resposta foi útil?
Pontuação 2
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 113
