iPhone 5 wifi greyed out even after wifi antenna replaced
So I bought an iphone 5 in eBay to fix it. The screen was totaled so I repaired that first... This is when I noticed the phone would not connect to wifi. I have done all the tricks and noticed the phone will connect to wifi for a short period after paced in the freezer. This drew me to the conclusion the wifi antenna had to be replaced.. After all of that work.. Wifi worked for not even a minute just to fall back to the original problem. Did the same ole trouble shooting and reset and restored the phone a hundred times.... and did the whole heat lamp trick and nothing... I'm at a dead end here... Any one have any ideas???
Esta é uma boa pergunta?
5 comentários
Where do I get it exactly? I was trying to find the parts for it and I'm kind of new to this. Thank you for the reply :-)
por keisha serrano
Ebay of course. But this is a difficult repair. BGA soldering required
por Tom Chai
To replace the wifi module do you pry the old chip off and clip the new one into place? Or is there more to it?
por keisha serrano
!@#$ ok... Well see how this goes lol.. Thank you
por keisha serrano
First you have to simply rehot the wifi module by hotgun with 180 and check most of the cases such fault was resolved by doing this.If the problem is still same even after doing this you have to replace the wifi chip.
por Akash
