Pular para o conteúdo principal
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1300 Perguntas Ver todas
My PowerBook doesent start with my new harddisk
I have installed a new harddisk but now it doesnt answer and start at all when I turn on the power button°!?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
Ok, but the problem is that the only thing that happens is that the "file" symbol is flashing when I turn the computer on
por
That's because there is no system. Put the disk in.
por
Your Mac MUST have a operating system to work properly.
por
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
4 Soluções
Solução escolhida
You need to format and install system on the new hard drive. Start up from the system installation disk by holding down the "C" key with the disk in the drive. Go to Disk Utilities on the second page pull down menu and format the drive. Mac OS extended should do. Then go back and install the system. Next, download and install the system updates by going under the Apple in the upper left hand corner to "Software Update". Keep updating until there are no more updates.
Esta resposta foi útil?
Pontuação 0
Comentários:
When starting up, if you see a folder with a question mark in it, that means it can't find a start-up folder. It will look on the hard drive and then the optical drive.
por
Pontuação 0
Comentários:
put the system disk in the cd drive and start up holding down the "c" key.
por
So what should I do?
Pontuação 0
OK, thanks for the answer/K
Pontuação 0
Adicionar a sua resposta
krister será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 710
