Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2396 Perguntas Visualizar todos
Why won't back glass come off?
So basically, my iPhone recently has been having problems charging and the touch screen is a little off so I was going to disassemble is, possibly replace the charging area (I have another iphone that doesn't work for spare parts) and make sure all connectors are in check. But the back glass wont come off. I removed both screws, took out the sim card, and I've watched videos on how it just slides up and out, but when I try to slide it, it's stuck. Won't move at all. Any idea what this could be?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
if your unscrewed the bottom screws your backglass must come out..
Sometimes it happens that a backcover is fully glued or stucked on your iphone's frame.
Your backcover must slide UP ( up is the side where your powerbutton is)
if it doesnt come up, hold the phone between your knees, one hand up and the other hand hold the phone steady.
hope this helps you out
Esta resposta foi útil?
Pontuação 1
4 comentários:
If this was the case and there was glue or adhesive sticking keeping it on, could I use a blow dryer or something of the sort to loosen the adhesive?
por
yes you can.. but 99% of the times you don't need. It's a bit strange that the backcover doesn't come that easily of your iphone. Maybe you threw a glass of cola or something like that for the rarest cases... it can happen :)
por
I tried and that didn't work either. What is up with this?! Any idea of what to do?
por
Okay jeez, I finally got it. I had to slide a super thin knife around the edges of the back slide. Apparently some super sticky adhesive or something. Seemed like super glue. So thanks!
por
Adicionar a sua resposta
Jackson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 13
Duração total: 2,157
