Ir para o conteúdo principal
The Black N Decker Toast R Oven TRO200 is a 4 slice under counter toaster oven with bake and toasting capabilities.
on/off button for toaster doesn't stay on
The on/off button for the my under the cabinet B&D toaster oven will not stay on. The oven part of the unit works fine. I see that the button can be replaced, but where do I get a replacement button?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I couldn't find a replacement oem button for the toaster, you can go to radioshack and pick up a toggle switch and try that or buy a new toaster. Sorry
Esta resposta foi útil?
Pontuação 0
3 comentários:
I have the same unit, I carefully, with a pair of pliers, adjusted the magnet so it aligned better with the switch mechanism.
It has been ok for me.
por
Where is magnet and how did you access it? Do I have to remove cover?
por
Magnet is same side as button and should stick to a little transformer ( 2 red wires from bread board). Just take the right side off and adjust the plate connected to button so it is flush when pushed in.
por
Adicionar a sua resposta
Linda Landrigan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 1,946
