Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
572 Perguntas Visualizar todos
I let the smoke out, what failed?
Following a wine spill on the keyboard, I let it sit to dry for 2 days. Apparently that wasn't long enough, or the computer may have been started up during that time (several people in the house).
When I tried starting it up, a small puff of smoke came out, and it immediately shut off. I'm going to disassemble it tonight, but I'm not sure I'll recognize what needs to be replaced. Any tips?== Heading text ==
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Found it, it burned up where the hard drive cable meets the logic board. Greeeaaaaaat.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Look for blackened and or burnt areas or components. Get the battery out ASAP
Esta resposta foi útil?
Pontuação 1
4 comentários:
Did it just burn the cable or the board also?
por
Here's a replacement hard drive cable, maybe that will suffice: MacBook Unibody (A1278) Hard Drive Cable
por
Unfortunately the board looks pretty toasted at the point where the cable connects, it will need a new cable as well though.
por
Replaced logic board and the cable, won't power on: Logic board replaced, won't power on..
por
Adicionar a sua resposta
Patrick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 959
