Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
pb g4 17inch heats up
hi,
i have pb G4 Aluminum 17" 1.5 ghz,
when watching movie, photoshop, illustrator, indesign it heats up. need help please.
thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It's normal for your PowerBook to heat up during heavy processor loads. But if you feel it's getting to hot it may be time to open it and clean out the fan and any other dust it may have gathered. I've opened these just to fine the fans fairly clean but upon removing the logic board found the vent almost completely blocked and the thermal paste 70% dried out. Here's the guide on replacing the thermal paste: How to Apply Thermal Paste
We don't have a teardown of the 1.5 model but the one for the 1.6 should be close enough. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Heat Sink & Fan Assembly Replacement
Imagem de Electronics Skills
Guia
Nível de dificuldade:
Moderada
5 - 20 minutes
Imagem de PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Heat Sink & Fan Assembly
Guia
Difícil
Esta resposta foi útil?
Pontuação 2
2 comentários:
good answer +
por
Hi,thanks for advice ,i will start now and see if cleaning will solve the problem, if not then will buy new Heat Sink & Fan Assembly, but please how much it cost + shipping to UK?
kind regards
por
Adicionar a sua resposta
ksinusi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 883
