Ir para o conteúdo principal
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
84 Perguntas Visualizar todos
Pergunta encerrada
My display panel is broken
I have an apple cinema display 24 inch.
I asked apple to repair it. They said the lcd panel is broken and that replacing that would cost 700 euro.
What lcd panel does the display have?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Lukas Guy, I believe that Apple uses a couple of different manufacturers for the monitor. The part number for the LCD is 661-4822 and the easiest way to verify that is by taking a look at the sticker on the back side of the panel. It is most likely a LG-Philips LM240WU6-SDA1, replacement cost around $400. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Many thanks.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 856
