Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3531 Perguntas Visualizar todos
How can I fix dents on the side of I phone 5s
http://www.youtube.com/watch?v=gWzqcjEbn...I drop down my iphone from 1 meter high and its dents on the side , i am thinking to find some same color paint and pain it but the surface is not flat anymore
Any ideas
Thank you
Esta é uma boa pergunta?
Pontuação 2
2 comentários
I have the same problem as yours, I remove the case and I accidentally dropped it from about 1 meter from my hand, but I don't know how to remove the dent.
por
Yes, that exactly same thing happened to me last tuesday :/ I was so mad to myself, because I just bought the iPhone 7 and already dropped it while I was cleaning it with a cloth. So, I remover the case for like 5 minutes and I managed to drop it
por
Adicionar um comentário
2 respostas
Solução escolhida
As long as the phone is still working I would leave it alone. If your phone is not working then you might be able to get a replacement under the extended AppleCare plan.
If this really bothers you see if you can get a case that covers it up. Paint won't stick to the metal very well and besides you would need to paint the entire edge so the one spot doesn't stand out. In doing so you could effect the phones operation (plugging up the mic & speaker holes)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks
I have ordered same color pain and will paint it, i dont like it really
por
Hi. I have the same problem as yours. I dented mine using a bandage scissor. then tried fixing it but instead got a scratch on the side of the dent. I guess you just need to cover the phone up. minimal damage is enough. and try not to look at it. that lessens the pain we feel. buy something that covers up the sides and back, and ignore it. :)
Pontuação 0
Adicionar a sua resposta
Stepan Petrosyan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 15,269
