Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Perguntas Visualizar todos
I cracked screen it wont turn on
I would like to fix my ipad 2 but don't I don't know what I need it doesn't turn on period
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
There are many reasons why your iPad won't turn on.
The obvious reason is because your screen is damaged and you can't see it working.
another reason is because the impact disconnected the battery and you have to connect the ipad via usb or to the wall to turn it on again.
You will need a heat gun to take off the screen from your ipad if you decide to follow the guide from ifixit.
Miguel
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
georgeespinoza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 591
