Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20011 Perguntas Visualizar todos
Pergunta encerrada
Can't start my MacBook, turns off when I release the power button
MacBook Pro early 2008
As the topic I can't start my MacBook. When I press and hold the power button i can hear the CD-ROM drive, fans, sleep mode indicator and my hard drive to start. But when I release the power button everything quits and I hear a quite beep sound from the side where the hard drive sits. The screen is black.
When I try to hold the power button longer (about 5 seconds) the sleep mode indicator start to flash fast and then the computer quits.
The problem started after I was working with logic pro and closed the screen for sleep mode. When I came back I couldn't start it. Lately my computer has been slow and my processor been almost working on maximum.
I have tried lots of things, resetting the SMC, safe mode (don't pass the release button), resetting PRAM, hold down ctrl + command + power, changing the RAM circuits with an old MacBook pro think 2006 model that works.
I thought it could be my harddrive so I tested it in the old MacBook and it worked (but it wanted me to resett to 10.6 or something).
My MacBook is running mountain lion.
Do someone know what the problem is and how to fix it.
Can you some how check what hardware is not working? It's a old computer and I don't want to put lots off money to fixit so I hope it's not the motherboard.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Might be the HD cable... try to boot with an external case or from a target booted other mac.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks for replying :)
I tried to start it from target booted macbook with a fire wire cable. But it didn't work. Could not find the hard drive and the MacBook who don't start still quits after I realese the power button :/
por
If it's no the drive that only leaves the cable / connector on the board.
por
From both the battery and the power cable to the board? Or do you mean the power to the hard drive?
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 416
