Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3531 Perguntas Visualizar todos
Can I put a iPhone 5 screen on a iPhone 5s?
Can i put a iphone 5 screen on a iphone 5s?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Pergunta mais útil
no
so are the iPhone 5 and iPhone 5s screens interchangeable
Esta resposta foi útil?
Pontuação 2
You answered "no" as if the link you referred to answered the question. I'm not sure if it is possible, I am not saying that. However if you had an iPhone 5s LCD assembly you wouldn't need the home button it would be attached to the LCD screen you would be replacing. Before everyone just takes everyone else's word for it, because The question actually has not been answered, maybe there should be more discussion before this subject is closed. There are many reasons for wanting to do this, for one I don't use my fingerprint scanner and could care less about it. I have about five iPhone five screens and they would come in handy because like everyone else I've broken my share of screens. I understand the parts from an iPhone 5s screen will not fit with an LCD from an iPhcone 5. But can anyone say for sure that the ribbon is not the same, if I recall the iPhone 5s just has an extra ribbon for the home button for the fingerprint sensor. The iPhone 5 LCD only has the home button attached to the entire assembly. The real question would probably be, does the LCD ribbon and digitizer ribbon fit the motherboard and also will the missing fingerprint sensor cause errors with iOS.
Pontuação 1
Bobby, the answer is no. The Ribbon cables and connectors are all different. The image should help you to see the difference.
Pontuação 1
no you can't because the new home button they are different and some more part
but you always can order one good quality in the online store or ebay
I find you here one for example :
http://www.ebay.com/itm/151269627651?ssP...
I hope that its help you :)
Pontuação 0
Adicionar a sua resposta
gaga323 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 23,455
