Ir para o conteúdo principal
The Jazz HDV178 is a sleek, point-and-shoot handheld camcorder with a 10 megapixel video resolution and 11 megapixel still picture capabilities.
3 Perguntas Visualizar todos
Pergunta encerrada
Why won't it power off when I close the screen?
My unit charges and when I swing the screen open it powers up and records fine but it won't power off when I close the screen like it normally did. If I take the battery out I can restart the process but if I forget it naturally drains down. I use it onboard to record our racecar so sometimes we get busy. I'm thinking a switch or sensor needs cleaning but nervous about taking it apart.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Fixed! I sprayed the hinge area with electric contact cleaner, moved the screen through its range of motion a few times and problem resolved.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 175
