Lower case and glue
Hi! my G4 400mhz titanium´s lower case is taking apart from the metal part in the battery´s place.
What can i do? Can i glue it? If so, what glue should i use?.
Best regards! and kind regards from the old Europe!.
Edit: the lower case where the screws are, the part that you take away from this powerbook.
Update
I would use it in the battery´s part, not in the logic board part.
Esta é uma boa pergunta?
And if i use an epoxy bicomponent,not the tipycal loctite??
por algoy
Thanks,i did vote you. I will take it apart again,glue it with epoxy,and wait at least 1-2 days. I think it did not leaves residue
por algoy
