Is a screen from a wet phone worth saving?
I have an iphone 4 that got wet and is not working. Can I remove the screen to use as a replacement screen?
Esta é uma boa pergunta?
It's worth a shot I suppose, it depends upon the extent of the water damage, if it was only a tiny amount then the screen may have survived the damage but if it was a little bit more then the screen would have most likely been damaged slightly. You won't really know if it's worth saving until you test it out.
The screen itself would probably still work but it will have visible water damage
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 93
