Problem with SSD MacBook Air A1304
Hi,
I have a problem with formatting SSD in MBA A1304.
I installed a new SSD (Samsung), went to Disk Utility.
SSD is visible but when I try to partition it, the process is never finished.
I checked this SSD on other laptop (Win), it works good, both partitioning it and formatting were success.
I checked the other HDD cable against my MBA and result is the same - partitioning is frozen.
So, both SSD and hdd cable are good.
What could be the reason? Motherboard?
Did anyone faced with the same issue?
Thanks.
Update
I use original MBA A1304 SSD Drive!
Please see my first post:
Any other useful ideas?
Esta é uma boa pergunta?
3 comentários
Oleg - Just to be clear here you are using the original SSD that came with your MacBook Air, correct? I think what got us confused here is you stated you have a new Samsung SSD not the original SSD (or HD) the system came with. If on the other hand this is a new Samsung SSD then the issue is within the SSD or its' connection not the system its' self as you can get it to see the SSD.
por Dan
Can you take a picture of your SSD so we can see the labels & chip markings. I'm thinking you have a SATA II or SATA III device Vs the needed SATA I.
por Dan
Are you able to setup a USB connected flash drive (partition, format & install the Mac OS onto it) on this system?
por Dan
