Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
840 Perguntas Visualizar todos
Toshiba Satellite A200-1JH Not booting after disassembly
Hi. I had to disassemble my Toshiba Satellite A200-1JH and I'd need to power it on with the top cover removed. To remove it I had to disconnect the speakers, the touchpad and the keyboad but I don't actually care about them (I have connected an USB mouse and keyboard); all the others cables and ribbon cables should still be connected. I attached my laptop to the power supply and pressed the power button. The hard drive started spinning and the DVD writer worked, but the display didn't turn on and after 1-2 seconds even the fan stopped. Can you help me please?
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Resposta
Solução escolhida
Removing and plugging back the RAM modules in resolved the issue.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jacopo Jannone será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 304
